RTX51 CAN Example Program for the Infineon C515C: Problems
Hi, I'm attempting to compile the RTX51 CAN Example Program for the Infineon C515C example from the keil website without much success. I'm using the PK51 with full RTOS.
I import the uVision version 1 project following the instructions on importing files from uVision version1. I changed the TARGET_PROC to 515, as this is the chip I hope to use. I've checked the environment, changing the frequency to 16Mhz for the CAN timing calculations.
The project compiles without error, but unfortunately produces linker errors.
UNRESOLVED EXTERNALS:
***WARNING L1: UNRESOLVED EXTERNAL SYMBOL
	  SYMBOL: ?RTX_PAGE_OUT_REG
              MODULE: C:\KEIL\C51\LIB\RTX51.LIB (RTXINT)
However the RTX51.LIB is not included in the project files, and when I add it to the target files it produces the same error.
I noticed that in PROJECT – OPTIONS FOR TARGET that the code banking check box has been configured checked, with a value of 32 banks. However in the project files the L51_BANK.A51 is not included, it is my understanding that L51_BANK.A51 has to be included and configured correctly when using Code Banking. When I include this file and configure it for use with the RTOS and make it compatible with target device. I get the following errors:
*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
	 SYMBOL: ?B_CURRENTBANK
MODULE: L51_BANK.obj (?BANK?SWITCHING)
***ERROR L102: EXTERNAL ATTRIBUTE MISMATCH
	MODULE: C:\…\RTX51.LIB (RTXCREA)
So I searched for ?B_CURRENTBANK and found it to be defined in RTXCONF.A51 and L51_BANK.A51. In RTXCONF.A51 it was defined as:
EXTRN DATA     (?B_CURRENTBANK)
What am I doing wrong? And why is there not a uVision 2 example from Keil?
