I'm trying to compile a C C51 based program using Keil compiler, v 7.04. sscanf works properly using the emulator, but hangs when running the application on the C51 based processor. Is there any known bug there ? Thanks in advance, Ignasi Villagrasa.
Can you give us more details of your problem? Which emulator (or is it simulator) and which CPU, target settings etc. regards Dejan
