I am evaluating uVision3. Everything works fine using Keil C demos. I have problems when trying to use GNU toolchain. - 'Use GNU Tools' selected - GNU Path specified Trying to buid blinky demo, I get the following messages: Can't open @.\obj\startup._ia for reading: No such file or directory compiling Blinky.c... arm-uclibc-gcc: @.\obj\blinky.__i: No such file or directory Can't open @.\obj\startup._ia for reading: No such file or directory Thank you in advance for your help
Yes, I had a previous installation, but it didn't work. Now I removed it and replaced with the one you suggested and now it seems working. Thank you.
Did you install the GNU Compiler? The GCCARM331.EXE is the setup program for the GNU Compiler.
