Hello, Have anyone experienced the ISD51 debugging issues after you successfully tested your code using Keil simulator and Hyperterminal? I used the following small code to try ISD51 debugging but no success at all. Hit the debug button and wait about 2s, there is an error message " ISD51 Error - communication problem with ISD51..." Can anyone give some ideas about how to solve this? I contacted Keil technical service and it seemed that they couldn't help it. My processor is C515C. My test code is below.
void main (void) { unsigned int i; Project_Init(B_9600); // Initialize Chip and Serial Interface #ifndef ISD51 // init ISD51 only when the uVision2 Debugger tries to connect TestSerial(); #endif #ifdef ISD51 // init ISD51 and start user program until the uVision2 Debugger connects ISDinit (); // initialize uVision2 Debugger and continue program run #endif #if 0 // init ISD51 and wait until the uVision2 Debugger connects ISDwait (); // wait for connection to uVision2 Debugger #endif EAL = 1; /* Enable global interrupt flag */ while (1) { #ifdef ISD51 // init ISD51 only when the uVision2 Debugger tries to connect ISDcheck(); // initialize uVision2 Debugger and continue program run Delay(200); #endif i++; } }
