C164 OTP programming
Hello!
I would like to program the OTP of a C164-controller the first time...-because I'm not so sure if I configured anything in the right way.So please could somebody take a look on this?:
The Pin EA will be hold high by a pull up resistor so it will be single-chip mode!-Does this mean,the BUSCON registers don't need to be handled (like waitstates...)?
I've read,the CAN module needs two waitstates,but isn't it hardwired configured so thát this is just an information?
Clockkonfiguration is done by the Keil 'OPTION FOR TARGET' menu-I think this works well for the OTP too?!
I think the configurations which are done by the startupcode and works well in simulator will do the same job using OTP?
Are there any other Pins which have to be pulled high??
Are there possibly registers I have to use only when the OTP is used for programm memory?I want to programm the OTP itself by the KITCON of Keil -I think the programming routine like in the manual will be done by the µVISION connected with the board?
I would be glad if somebody could help me and saves the Controller for beeing mistreated!
(P.S.special greetings to MR Bruno.C. who helped me last time!)
