I have a structure defined as typedef struct example{ int a; char b; example c; }STRUCT_EG; and I declare a pointer to this structure as STRUCT_EG *Struct_ptr To check whether the pointer is pointing to NULL I use the following "if" statement if (Struct_ptr == (STRUCT_EG*)0) I was wondering whether this method is acceptable as I could not get it to work correctly (ie the "if" condition doesnt go through eventhough the pointer is null). Are there any other ways which I can use? Please advise. Thank you.
if (Struct_ptr == NULL)
if (Struct_ptr == 0)
