Pointer to NULL structure
I have a structure defined as
typedef struct example{
int a;
char b;
example c;
}STRUCT_EG;
and I declare a pointer to this structure as
STRUCT_EG *Struct_ptr
To check whether the pointer is pointing to NULL I use the following "if" statement
if (Struct_ptr == (STRUCT_EG*)0)
I was wondering whether this method is acceptable as I could not get it to work correctly (ie the "if" condition doesnt go through eventhough the pointer is null). Are there any other ways which I can use?
Please advise. Thank you.
  • if (Struct_ptr == (STRUCT_EG*)0)
    That should work. The simpler construct
    if (Struct_ptr == NULL)
    should, too, assuming you've #include'ed at least one of the Standard C headers that #define NULL (e.g., stdio.h or stdlib.h).
    Actually, even
    if (Struct_ptr == 0)
    has to work. If it didn't, that'd be a compiler bug.
    [A reminger: the tag to put code samples in is < pre >, not < b >.
    Actually, even
