Memory allocation and segment definitions
Hello all,
My goal is to get some variables placed in EEPROM without hardcoding it to a fixed address (using the _at_ keyword is unfortunately not an option).
The variable shall be assigned to a certain segment and then the linker should take care of the rest.
The problem is that the RAM of the chip is within the same address-range (xdata) as the EEPROM and Keil seems to make use of xdata in a linear structure so that it will first use up all the RAM (0-0x03FF) before it starts placing variables in EEPROM (0x03FF-0xFFFF).
I know that theres a USERCLASS-directive which the kind people here at Keil pointed out to me, but I cannot get it working. I tried every possible combination I can think of and also all the tips I got from Keil-support but no luck yet.
Do you have any suggestions as to what I might change or what Im doing wrong ?
Ive posted a small program that demonstrates the problem.
The challenge is to get variable B placed inside the XDATA_DANSCLASS area of the xdata, that is between 0x3000 and 0x4000 of xdata.
If you can do that please let me know !!!
As the project is now it will compile but not without a linker-error (L107) "Address Space Overflow"
Why this problem ???
If you look at the map-file theres lots of space left, - I cant see why the linker complaints about this ?
Please dont hesitate to post a message if you need more info in order to help.
Heres the source:
#pragma userclass (xdata = DansClass)
#define DansClass xdata
void main()
unsigned char A;
DansClass unsigned char B[0x80];
A=0;
B[0]=A;
The LX51-control userclasses-tab inside options-for-target -> LX51-Locate is set to:
XDATA_DansClass(X:0x3000 - X:0x4000)
Here's the resulting MAP-file.
CPU MODE:     8051 MODE
MEMORY MODEL: LARGE
ACTIVE MEMORY CLASSES OF MODULE:  Test (MAIN)
BASE        START       END         USED      MEMORY CLASS
X:000000H   X:003000H   X:004000H             XDATA_DANSCLASS
C:000000H   C:000000H   C:00FFFFH   000015H   CODE
I:000000H   I:000000H   I:0000FFH   000001H   IDATA
I:000000H   I:000000H   I:00007FH   000008H   DATA
X:000000H   X:000000H   X:00FFFFH   000080H   XDATA
MEMORY MAP OF MODULE:  Test (MAIN)
START     STOP      LENGTH    ALIGN  RELOC    MEMORY CLASS   SEGMENT NAME
* * * * * * * * * * *   D A T A   M E M O R Y   * * * * * * * * * * * * *
000000H   000007H   000008H   ---    AT..     DATA           "REG BANK 0"
000008H   000008H   000001H   BYTE   UNIT     IDATA          ?STACK
* * * * * * * * * * *   C O D E   M E M O R Y   * * * * * * * * * * * * *
000000H   000002H   000003H   ---    OFFS..   CODE           ?CO??C_STARTUP?0
000003H   00000EH   00000CH   BYTE   UNIT     CODE           ?C_C51STARTUP
00000FH   000014H   000006H   BYTE   UNIT     CODE           ?PR?MAIN?MAIN
* * * * * * * * * * *  X D A T A   M E M O R Y  * * * * * * * * * * * * *
000000H   00007FH   000080H   BYTE   UNIT     XDATA          _XDATA_GROUP_
OVERLAY MAP OF MODULE:   Test (MAIN)
FUNCTION/MODULE             XDATA_GROUP
--> CALLED FUNCTION/MODULE  START  STOP
?C_C51STARTUP               ----- -----
  +--> ?PR?MAIN?MAIN
MAIN/MAIN                   ----- -----
PUBLIC SYMBOLS OF MODULE:  Test (MAIN)
      VALUE       CLASS    TYPE      PUBLIC SYMBOL NAME
      00000000H   NUMBER   ---       ?C?CODESEG
      00000000H   NUMBER   ---       ?C?XDATASEG
LX51 LINKER/LOCATER V3.58
      0100000FH   CODE     ---       ?C_START
      01000000H   CODE     ---       ?C_STARTUP
      0100000FH   CODE     ---       main
SYMBOL TABLE OF MODULE:  Test (MAIN)
      VALUE       REP       CLASS    TYPE      SYMBOL NAME
      ---         MODULE    ---      ---       MAIN
      0100000FH   PUBLIC    CODE     ---       main
      0100000FH   BLOCK     CODE     ---       LVL=0
      0100000FH   BLOCK     CODE     NEAR LAB  LVL=1
      00000007H   SYMBOL    DATA     BYTE      A
      02000000H   SYMBOL    XDATA    ---       B
      ---         BLOCKEND  ---      ---       LVL=1
      0100000FH   LINE      CODE     ---       #4
      0100000FH   LINE      CODE     ---       #5
      0100000FH   LINE      CODE     ---       #10
      01000010H   LINE      CODE     ---       #11
      01000014H   LINE      CODE     ---       #12
      ---         BLOCKEND  ---      ---       LVL=0
      ---         MODULE    ---      ---       ?C_STARTUP
      01000000H   PUBLIC    CODE     ---       ?C_STARTUP
Program Size: data=9.0 xdata=128 const=0 code=21
LX51 RUN COMPLETE.  0 WARNING(S),  0 ERROR(S)
