C167 reading/scanning input from GSM module from RS232
I am a novice in C language and have been trying to find a method of reading/scanning input from GSM, then comparing it against a text (e.g OK or ERROR). Then if true set a break.
I have tried scanf with no avail. I have also tried reading string which works but am unsure how to compare with my text.Has anyone any advice with what function would be useful?
Any replies greatly appreciated.
Andy
  • "reading/scanning input from GSM, then comparing it against a text (e.g OK or ERROR)."
    These textual messages - OK, ERROR, CONNECT, RING, etc - are designed for use by a human operator sitting at a terminal and typing commands; they are not intended for machine interpretation.
    You will make you life very much more difficult by trying to read & parse these human-oriented messages in your software.
    These messages are known as the "Verbose" (or "Verbal") forms; there is also a "Terse" (or "Numeric") mode - intended specifically for machine-oriented interactions.
    In "Terse" mode, the modem gives simple numeric code responses - much easier to handle in software!
    Look for ATV in your modem's Manual
