How many clock cycles does a EMOV instruction take? I was not able to finc this in the instruction manual. Thanks in advance.
This information is in the Philips User's Manual. It is 4 states on most MX devices.
4 states means 4 clock cycles ?
4 states means 4 clock cycles ? If you have to ask that you need read the manual. If instruction timing is important to you you need the basic knowledge that enables you to answer that question yourself. Erik PS the answer is no
Thanks for your reply.
