currently, i am able to get 8bit data from ADC to the micro-p using D0-D7. i want to convert the 8bit data to temperature reading on the LCD. since 8bit data there are total 256 combination and each step would be: x = 100/256; //to get the each step temperature. in this case is 0.39 dC y = inputval*x; // i get the inputval from D0-D7 and mult by x to give me the exact temperature val in y. but how can i covert it into asiic? when i programme my LCD put char as: lcdClrScr(); lcdPutStr("N:Jepthah"); //the enclosed will be displayed on the screen therefore it would be ricdulas to dump the y lie this: lcdClrScr(); lcdPutStr("Y"); because it can display the 'y' char rather than the temperature value. I need help, thanks!
sprintf() Stefan
do it need to include in files like #include <stdio.52h> #include <utl.h> etc....????
"do it need to include in files like #include <stdio.52h>" Read the Manual! The description of each library file tells you what headers it needs!
as stefan has mentioned sprinf(}; do i simply just put sprintf("Tempreture = %f\n", y); //???
You need to look sprintf() up in the C51 manual. There you will find a description of the parameters and output. Stefan
Note that the Keil Manuals assune that you are already a competent 'C' programmer - they do not even attempt to teach you 'C' programming. From your questions, it looks like what you really need is a good beginners 'C' textbook. Better still, a C programming course.
