Problem with serial port
I've done a program using the simulated serial port. My program has to
communicate with a PC using the 232 interface, so I use the simulated
serial port for the monitor, and the 232 interface for the program. The program
works.
The problem is when I burn the program in ROM, because I want it starts when I switch on the board. Then I erase the monitor program in the flash, and I burn my program in the external ROM. Then the communication 232 doesn't works. What is happening??. Here you can see my configuration of the
serial
port:
S0BG = 0x0040;
DP3 |= 0x0400; /* Set TXD for output */
DP3 &= ~0x0800; /* Set RXD for input */
P3 |= 0x0400; /* Set TXD high */
tx_restart = 1; /* Set restart flag */
S0CON = 0x8019; //8 bits, 2 stop, no parity
S0RIC = 0x0076; //Interrupts RX
S0TIC = 0x0075; //Interrupts TX
S0TBIC = 0x0077;//Interrupts buffer TX
The same program works from the RAM with monitor in ROM. I've tried using DAVE, but I haven't got any improvement. Can anybody help me?
Thank you
