89LPC932 Reset Pin
Hi, I want to use the reset pin on the LPC932. This pin (P1^5) will reset the micro after bringing it low. My question is about the procedure.
1. I write a 1 (high) to this pin (reset).
2. Then I put a NO (two pin) button between the reset pin and ground.
3. When I press the button (its pins close) the reset pin should go low and a reset is performed.
Is this the right way to do it?
Thank you
