Hi, Iam interested in getting the number of clock cycles taken by each instruction in the listing file (LST file). Is there any option to do this with c51?. (or) Is there any other way to get the number of clock cycles for each instruction of a C program. I did it for COSMIC ST7 compiler. Looking forward for your reply. Thank you. Regards, sivakumar
Hi all, Thank you very much for your help Have a nice day. --siva
On the other hand, if it's The Bible that you're after, try: http://bible.gospelcom.net/bible?search=ask+seek+find&SearchType=AND
The documents commonly referred to as "the bible" for the 8051 are: http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_ARCH_1.pdf http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_PROG_GUIDE_1.pdf http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_HARDWARE_1.pdf The PROG_GUIDE is the one that includes the Instruction Set description, and timings for the standard 8051 The instruction set is the same for all variants, but the timings will differ on "accelerated" variants. Vendors will be keen to point out the advantages of their products, so it should be easy to obtain details of the "enhanced" timings...!
"where can download to download "the bible". I searched in the web iam not able to find it." What, no hits at all? Search this forum for "the bible" and follow the second hit. Stefan
Hi, where can download to download "the bible". I searched in the web iam not able to find it. Please help me. Thanks in advance. --siva
where can i get the timings for each opcode In this funny little document called the datasheet. If you are using a '51 derivative where the instruction cycles are standard (most derivatives), you can find it in "the bible" chapter 2 - remember to look in the datasheet for how may clock cycles to an instruction cycle. Erik
hi, Thanks for your fast reply. sorry for disturbing you again. where can i get the timings for each opcode? --siva
See VLOOKUP in the Excel help. You will need to create the table yourself, with the timings appropriate to your particular variant. You need the timings for each OpCode
hi, What is a look up table? where can i download it? Looking forward for your reply. Thanks. --siva
I get Excel to do it! Use a lookup table - the number of cycles is known from the opcode.
