I wish to display the contents of a variable, probably an unsigned integer, on an lcd display driven from the 8051. I have written software to accept an array of characters and write these, so the ideal would be to creat a similat array from the variable. I have tried the basic ways I know of, sprintf (char_array, "%d", integer_value); (very low tech) but dosent work. Any pointers would be greatfully recieved, Thank you, Tim
If the number is an unsigned integer,you may have to use %u instead of %d in the sprintf function to get the correct string. sprintf (char_array, "%d", integer_value);
Note that unless you enable ANSI integer promotion, a byte variable cannot be printed with "%d". Those format specifiers only work with integers, which are two bytes long. To print bytes, you need to use "%bd" (etc), in much the same way you need "%ld" for a 32-bit long.
