Hi, I'm trying to learn the MULTI-TASKING concept using RTX51 Tiny. I noticed that you no longer use the main. You always start with TASK 0. But If I need to INIT my MCU, how do I proceed ? Because if I put my init() in the TASK0, my MCU will be initialized several time, no ? Help a newbie ;-) Thx
I usually have several different sorts of initialization. - pre-kernel initialization. Relatively rare except for the C runtime and board support type stuff. But sometimes you need to do low-level initialization before anything else happens. This corresponds to Keil's STARTUP.A51, INIT.A51, and perhaps some other code. - pre-start initialization main() calls a bunch of init functions for various modules before any task starts running. These functions often create tasks, among other things.
void main (void) { ModAInit(); ModBInit(); ModCInit(); // start system running StartOs(); }
void TaskBody (void) { // startup init TaskInit(); // never-ending task body for (;;) { // task activity e = WaitForEvent(); HandleEvent (e); } } // TaskBody
Task 0 is the entry for your program. It must contain a 'forever' loop such as a while(1){...}. Just put your init prior to the while(1) loop. It will init only one time.
