My name is Sepeci a student working on a project using nordic 2.4Ghz evaluation kit to transmit and receiver data between two PC. Need help for a C code using keil to perform the above task.
Start by reading the documentation available from Nordic? Don't they have any examples?
sir, i m an engineering student making a project of serial communication between 2 pc using 2.4Ghz wireless. plse help me send me some detail on it. thanks rakesh kumar yadav
Start by reading the documentation available from the supplier of your 2.4GHz transceivers. Don't they have any examples?
No they dont have example and I have trying to find one. assistance will be highly appreciated. thanks sepeci.
In that case, you'll need to give more details - like: What transceivers are you going to use? How do you intend to use them for this link? What interface do they provide to the PC? Hint: is is generally best to start without the RF link, and just use a direct wired connection to get your two PCs talking. Once you've got that bit working, then you can move it to RF. Of course, this is a forum for discussing Keil tools - not PC programming. There's plenty of other resources on the internet for PC programming.
