pc-lint problem
I am using uVision2 version 2.37 and pc-lint version 8.00o.
I have included the co-kc51.lnt and env-keil.lnt in the setup, as well as the pertinent include file paths.
All I get is PC-Lint running and the header. I have checked to make sure that the env-keil.lnt contains the right info.
I'm at a loss.
If I try to run if from a batch file, it seems to run but can find the ansi standard header files and they are not in the Keil directory
Any ideas would be welcome
  • This is the project-specific lint file that I use:
    -ic:\lint\lnt
    // Keil C51
    co-kc51.lnt -si4 -sp4
    // Codewright editor
    env-cw6.lnt
    // include paths for project
    -ic:\Keil\C51\inc
    // four additional project -i here
    -e537			 // repeated include file
    -e655			 // bit-wise op uses compatible enums
    -esym(553,DEBUG) // undefined, assumed 0
    -esym(788,*Num*,*Force16*)  // enum constant not used in switch
    -e834			// operator '-' followed by op '-' is confusing
    The ANSI headers are in c:\keil\c51\inc on my machine, which I think is the standard installation. You'll still need to tell lint where to find them, though.
    -ic:\lint\lnt
    // Keil C51
    env-cw6.lnt
    -ic:\Keil\C51\inc
