over ambitious code optimisation
I have a memory mapped A/D converter (with a conversion time << one machine cycle, therefore no need to check for End of Conversion). The following code was written to explain the problem: -
xdata unsigned char A_D _at_ 0xE000;
//this is the address of the A/D converter
unsigned char x,y;
main()
A_D = 0;
//start conversion by doing a "dummy write"
x = A_D;     // read the value from the A/D
This all looks fine, but when I look at the assembly code: -
     CLR A
     MOV DPTR,#A_D(E000)
     MOVX @DPTR,A
     MOV x(0x80),A
the "dummy write" is OK but we obviously DO NOT read from XDATA address 0xE000. The only way to "FIX" the problem is to insert some code between the write and read operations that make use of the accumulator.
Clearly, this will be a problem where a write only device and a read only device share the same address, as is the case with many programmeable peripheral devices.
