If I want to use EPM900 as parallel programmer, how to connect the target P89LPC932 ? Just connect every pin of MCU to the pin labeled the same name of the connection on EPM900 board? Thanks~~
Yes, there are also programming adapters available. See under: http://www.keil.com/support/docs/2562.htm
