Hellow all, In the uVision 2.0 for 8051, how to determine the exact No. of cycles taken to execute a C Language statement? Given that performane analyzer works only on complete functions, not on a single line basis. e.g. Temp = P2; // Takes (??) cycles Array[Counter] = Temp; // Takes (??) cycles If(SignBit == 1) // Takes (??) cycles Temp = 0xF0; // Takes (??) cycles else Temp = 0x0; // Takes (??) cycles Thanks in advance for your time.
In the uVision 2.0 for 8051, how to determine the exact No. of cycles taken to execute a C Language statement? The following knowledgebase article terlls one way to do this. http://www.keil.com/support/docs/971.htm Given that performane analyzer works only on complete functions, not on a single line basis. That is not correct. The performance analyzer works on ranges of code as well as functions. To define a range in the Performance Analyzer Dialog, you must specify the starting address, a comma (','), and the ending address. You may use file/line number IDs if you like, For example \main\23 refers to line 23 in the main source file. Jon
