Adding NOP at 0000h, revisited.
I read the following document to add a NOP before the LJMP at address 0000h. (http://www.keil.com/support/docs/1622.htm, Size 5,096 bytes, Jun 20, 2000) But, I'm still not clear on how to do it. I followed the instructions, but nothing was changed in the final object code. I'm using uVision2 IDE. Do I need to specify the new directory for startup.a51? Where?
The reason I want to do this is because my 8032-based board is not getting set up properly at power up. It was suggested to try this. Only after a manual reset, the program executes properly. The RC power-up reset is 100ms.
