When I debug the following program, received an errno: ***errno34: undefined identifier #include <rtx51tny.h> #include <reg52.h> #define INIT 0 #define ONE 1 #define TWO 2 int counter1; int counter2; void initial(void) _task_ INIT { os_create_task(ONE); os_create_task(TWO); os_delete_task(INIT); } void job1(void) _task_ ONE { while (1) { counter1++; } } void job2(void) _task_ TWO { while (1) { counter2++; } } But when I select "go" from debug menu, I can see the tasklist. That's why? Thanks. (Keil V6.20)
Which line generates the error?
No errors generate when building, but when I select "start/stop debug session" from debug menu, I received this error. Keil do not tell me what line generate this error, only the error code and simple text: error34: undefined identifier.
You probably have a debug script which tries to view or watch a variable that is not currently in scope. Jon
