How to move the 167 stack?
Hi!
For various reasons, I want to position the internal 167 stack so that it starts at the bottom of internal RAM (F600 on the C167CR), and extends 512 bytes up (i.e. to F7FF). This of course requires modification to the START167.ASM startup code. However, L166 still locates the stack at the default location of FA00..FBFF (as can be seen in the .map file). Looking at the linker SSKDEF directive definition, it implies that the linker indeed automatically puts the stack at these addresses when a 512 byte stack is selected. However, in the 167 chip manual, I can see no reason for not placing the stack anywhere in the internal RAM, as long as the appropriate registers are properly initialized (SP, STKUN, STKOV).
So my question is ... how do you get the linker to allocate the stack where I want it? (I'm still using the old 3.xx tool series, perhaps this has been fixed in the 4.xx versions?)
regards,
/Ricard W
