Hi~ All I have write a RTX51 test program with AT89C51, see following code: #include <reg51.h> #include <rtx51tny.h> void init (void) _task_ 0 { os_create_task (1); os_create_task (2); } void LED (void) _task_ 1 { P2=0; } void LED2 (void) _task_ 2 { P2=1; } and this compile is OK, but when debug run something error: error message as below: *** error 65: access violation at I:0xFE : no 'write' permission but when I change to at89c52, the same code is OK. So is there something wrong in RTX51?
That message means that the simulator doesn't believe there's any IDATA memory at that address. Cross-check that with the data-sheet, and your settings in the target options dialog of uVision2 , please.
As far as I remember, 89C51 has only 128 bytes of internal RAM, so 0xFE is out of address space. regards Dejan
Task 1 and task 2 set P2 and then exit. they never run again. You should probably have a while (1) at the end of each of these functions. Additionally, task 0 also just exits. This is probably NOT what you should do. Calling os_delete_task is the best idea if you just want to kill off these tasks. Jon
Thanks for the replies~ I think I found the problem. Just as Dejan says, 89C51 only have 128 bytes rams, and RTX51 defaulty uses 256 bytes rams, so problems happened. We must change Ramtop value from 0xFF to 0x7F and it works.
Hi. RTX51 tiny required 256Bytes Internal RAM. Only 89c52 or higher. One task 3*IDATA. RTX51 Full need external XDATA. Your definitions task is incorrect. Good bye.
void Job1(void) _task_ 1 { while(1) { P3=~P3; } } void Job2(void) _task_ 2 { while(1) { P1=~P1; } } void Job0(void) _task_ 0 { os_create_task(1); os_create_task(2); os_delete_task(0); }
Hi~ Thanks for your advise,Just as I say before,RTX default need 256 bytes, but we can modify the ram size where on the CONF_TNY.A51. So it works on AT89C51 too. Hopes this is use for you ^_^
