Using external RAM on the XC164 development board
Has anyone been able to use the external RAM on the Infineon XC16x development board in 16 bit multiplexed mode?
I've wrote a small RAM test application that will read and write all memory, but the external RAM always trips up after a few seconds.
I suspect the timings may be out on this, since it works most of the time, but will fail eventually. I have the following values:
Phase A = 0 cycles
Phase B = 0 cycles
Phase C = 1 cycle
Phase D = 0 cycles
Phase E = 0 cycles
Phase F read = 1 cycle
Phase F write = 0 cycles
Does anyone know a set of timing values that work? The micro is an XC164CS running at 40MHz, and the memory chip is a Samsung K6R4016C1D.
Incidentally, the RAM test program shows the memory working perfectly in non-multiplexed mode. The timings are different for non-multiplexed, but give worse results when used in multiplexed mode.
Any help appreciated!
Thanks,
Paul.
