Debugging With Simulator
friends,
I am working in an LCD keypad module for an industrial controller using AT89S52 processor. Developemnt platform is KEIL IDE. I have done the coding and right now i am doing testing of coded modules. For this i am using in built simulator of keil. here i am experiencing some problems.
I real case all the pins are pulled up so when ever key stroke occcur the corresponding pin will be GNDed. once the key is released i goes back to high again. How this situation cud be simulated in keil. I wrote a debugging function to give external I/P to port pin to signify key strokes. that func is activated on pressing a button. But i have to presss another button to bring port back to norm state. by this time the program would have taken many keystrokes. So i want somthg which will bring port pins back to norm state once keypins are read by simulator. this kinda situation wont arise if you use an in circuit debuger.
Thank you
Nitin S
