I have found just one paper about Winbond W77E532. As for the onchip banking technology, there is just one paragraph:"En128K:on-chip ROM banking enalbe. Set this bit to enable APFLASH0 and APFLASH1 by banking mechanism. By default, P1.7 is defined as A16". When I enable this feature, my program crashed. Why?
Has anybody in this forum been successfull using code banking on W77E532? We still can not find a "reliable" method to do this as yet. Sometime the the code hung, and other time it behaves erratically. JIMMY
SILabs http://www.silabs.com/tgwWebApp/appmanager/tgw/tgwHome?_nfpb=true&_pageLabel=GenericContentPage&contentObjectId=/public/web_content/products/Microcontrollers/en/index.htm has on-chip code banking and it works there. If the Winbond on chip code banking is the same there may be some help to find in the SILabs litterature. I have no idea in either case since my attitude is that if you need code banking you have chosen the wrong chip. Erik
Thanks, I find that Silicon Lab website has a lot more usefull information than Keil 's website with regard to Code banking. I have never found any documents from Keil's talks about code banking using processor internal flash memory beyong 64K. JIMMY
can u control code banking now? i have same problem with u.
Yes, but we did a slight different than what we found on the web. Each chip requires different treatment as far a code banking. You really have to fine tune your code setup to that particular chip. JIMMY
I am using w77e532 now,the same with u. and the configuration settings in l51_bank.a51 ?N_BANKS EQU 2 ; Two banks are required. ?B_MODE EQU 4 ; User-provided bank switch code. ROMSIZE DATA 0ABH ; SFR Address SWITCH0 MACRO ; Switch to Memory Bank #0 MOV ROMSIZE,#05H ; Enable on-chip 16KB ROM ENDM SWITCH1 MACRO ; Switch to Memory Bank #1 MOV ROMSIZE,#00H ; Disable on-chip 16KB ROM ENDM But didn't work.. Is the w77e532 same framework with on-chip ROM in User's Guild?
What you have done still incomplete. You need to read part spec under memory banking for that chip.
