C164CI: How to set CAN Pins to Port 8
I am looking for a way to change the CAN-port-pins from port 4 to port 8 (because of the need of all adress-pins). The Infineon doc talks about register C1PCIR (3 IPC Bits). When I set these bits from 000 to 010, (Instruction C1PCIR = 0x200) like the manual says, the KEIL-CAN-Debugger shows me after step over, that the old contents of 0xFF00 is repeatingly stored in the register. Whats wrong?
Has anybody routet the CAN-Pins to another location than default?
Thanks a lot...
Mike
  • I have been trying to do the same in the 167CS, but it seems that fails because the response of the CAN bus is a bus-off error. I didn't traced the status of the chip, but with your information it seems to logical the error i receive. Please tell me if you find a correct way to do it.
    Thanks in advance.
    Thanks in advance.
