working with Hyper terminal
Hi
I have been trying this code using uVision emulator and it works fine, then I download it to the Infineon C167CR-L and again works fine using Monitor. I stop debugging and connect the serial port to my PC using Hyper Terminal and works fine also but when I reset the unit or I just switch off the power supply, it doesn't work right anymore. The screen on HT (Hyper Terminal) starts to display a lot of spaces, ooooos or smiles but the program doesn't work as it did using Monitor. Any advice on this?
Define Port 7, Direction Register, and Open Drain Register.
#include <stdio.h>                /* standard I/O .h-file              */
#include <reg167.h>               /* special function register 80C167  */
char cmd;		       /* Store value received from port 3 here */
MAIN C Function
void main (void)
Configure P2.15-P2.12 as Outputs.
DP2  = 0xF000;    /* Configure P2.15-P7.12 for output, */
ODP2 = 0xF000;    /* Setup P2.15-P2.12 for open-drain */
 						/* initialize the serial interface     */
#ifndef MCB167          /* do not initialize if you use Monitor-166      */
  P3  |= 0x0400;        /* SET PORT 3.10 OUTPUT LATCH (TXD)              */
  DP3 |= 0x0400;        /* SET PORT 3.10 DIRECTION CONTROL (TXD OUTPUT)  */
  DP3 &= 0xF7FF;        /* RESET PORT 3.11 DIRECTION CONTROL (RXD INPUT) */
  S0TIC = 0x80;         /* SET TRANSMIT INTERRUPT FLAG                   */
  S0RIC = 0x00;         /* DELETE RECEIVE INTERRUPT FLAG                 */
  S0BG  = 0x40;         /* SET BAUDRATE TO 9600 BAUD                     */
  S0CON = 0x8011;       /* SET SERIAL MODE                               */
#endif
printf ("Robot ready to receive commands ");
while (1)					/* An embedded program never stops and returns */
  {						/* Here is an endless loop to solve this and   */
  						/* monitor serial port                         */
     scanf ("%c", &cmd);
	 printf ("%c\n", cmd);
/* Check for direction robot */
	switch(cmd)
		case '8' : P2 = 0x0000; break;
		case '2' : P2 = 0x5000; break;
		case '4' : P2 = 0x4000; break;
		case '6' : P2 = 0x1000; break;
		default  : P2 = 0xA000;;
Ed
(I hope I have explained myself ok, my english is a little bit rusty)
Ah! I'm using a phytec development board
