DSEG AT Directive Problem
I am having some difficulty with using the Keil A51 assembler. My 8051 derivative processor has 256 bytes of internal RAM. I have my code organized with a...
BSEG AT 0
BIT1 DBIT 1
BIT2 DBIT 1
BIT3 DBIT 1
BIT8 DBIT 1
Following this I have the data segment setup as starting at 0x21 because I know that the BSEG will be but one byte ending up at 0x20.
DSEG AT 021H
VAR1:
   DS   1
VAR2:
   DS   1
VARn:
   DS   1
BUF1:
   DS   32
BUF2:
   DS   26
BUF4:
   DS   16
BUF5:
   DS   16
STACK:
   DS   16
_RAM_TOP:
   DS   0
Now the problem is that the DSEG is growing beyond 0x7F (past end of 128 bytes) and the assembler is complaining about that. How can I get the assembler to quit complaining. All should be OK becasue in my code all of the various buffers are accessed indirectly by the type of code:
   MOV   R0, #BUF3
   MOV   @R0, A
I realize I could hard code a separate PSEG at 0x80, but then there ends up being a hole in the allocated memory and I wanted to avoid that to get the maximum utilization of my 256 bytes of RAM.
Any ideas ????
Michael Karas
<pre
  • I solved my problem. I guess the biggest difficulty came from trying to use the type of absolute segment declaration I was using. I went to relocatable segments as shown below and let the linker decide where to put things. Now all is better!!
    BITS_SEG    SEGMENT     BIT
    DATA_SEG    SEGMENT     DATA
    BUFF_SEG    SEGMENT     IDATA
    CODE_SEG    SEGMENT     CODE
         RSEG    BITS_SEG
    BIT1:
         DBIT 1
    BIT2:
         DBIT 1
    BIT3:
         DBIT 1
    BITn:
        DBIT 1
        RSEG    DATA_SEG
    VAR1:
        DS   1
    VAR2:
        DS   1
    VARn:
        DS   1
        RSEG    BUFF_SEG
    BUF1:
        DS   32
    BUF2:
        DS   26
    BUF3:
        DS   16
    BUFn:
        DS   16
    STACK:
        DS   16
    Michael Karas
         RSEG    BITS_SEG
    BIT1:
         DBIT 1
    BIT2:
         DBIT 1
    BIT3:
         DBIT 1
    BITn:
        DBIT 1
        RSEG    DATA_SEG
    VAR1:
        DS   1
    VAR2:
        DS   1
    VARn:
        DS   1
        RSEG    BUFF_SEG
    BUF1:
        DS   32
    BUF2:
        DS   26
    BUF3:
        DS   16
    BUFn:
        DS   16
    STACK:
        DS   16
    Michael Karas
