Dear sir.. i want to do image processing application such as zooming ,flipping ,-veing,splitting,rotating,saving in to ram and recalling that from ram.In 8051 c keil cross compiler but keil dosnt support graphics appliaction so is it possible to developed such application in keil.do u have some algorithm and any books name then please send it to me ,waiting for ur +ve response,thanks ezhar
"but keil dosnt support graphics appliaction" Keil's is an ANSI 'C' compiler - so, if you can do it in ANSI 'C', you can compile it with the Keil compiler. And, of course, everything you say can be written in ANSI 'C'. HOWEVER, the question you need to ask yourself is: do you actually have suitable 8051-based target hardware to actually run all this stuff? It's pointless writing & compiling it if you don't have suitable target hardware to run it!!
Image processing is a task that is traditionally solved on digital signal processors. The 8051 architecture does not fit in this case.
Dear all, 8051 is controller, its design for control application. if you want to do image processing, please go for FPGA or CPLD. please have a look web site http://www.xess.com, you will fine best hardware for image processing application. Gaurav Kumar Modi Electronics Design Engineer U.K
