How to burn a large volume of bytes (>40k) into the eprom?
I read the previous discussion on creating data-only hex file, http://www.keil.com/support/docs/2070.htm. The problem is that I cannot hard-code the bytes in an array, like,
   const code my_bytes[] =  { _byte1, _byte2, _byte3 };
The reason is that the number of byte is too big (>40k), thus I have to read them from a file.
As matter of fact, this set of bytes is a Java bytecode. First, I load a set of C codes which runs as the Java VM. Second, The VM reads the Java bytecode from a fixed address. In other words, my question is how to load the Java bytecode to a specified location.
Many thanks beforehand,
Kan
