Change from CA step to DA C164 8EM chips causes 8 " slowdown.
I am recently changed to Infineon C164 - 8EM DA revision chip (64K OTP ROM) in standalone mode (EA pin high). The CA revision has always worked fine in standalone with exactly the same sw code.
When changing to to newer DA verion The software runs eight time slower (i.e. instead of the external 5 MHz clock multiplied by 4 it divides it by two!).
I've updated to the latest startup.a66 (extended architure) code with programs the syscon 2 registers and should take care of CLKCFG for clock PLL generation. But no matter what I do the chip seems to runs at 2.5 Mhz. Surely other people have used the DA chip ok?
