my purpose is to generate two opposite square signals of 40khz (period 25 us ) for a time of 400 us ie 16 periods then to regenerate that after about 100ms : ( ie 400us of 40 khz each 100ms). i'm using timer2 in the whole project i should stay in x2 mode i'm using the AT89C5115. so using the timer2 i generate an interruption each 12.5 us in which i toggle the two pins i'm using to have my two square signals so i obtain half a period. by means of a counter set at 32 then decremented if the counter is zero i'll set to count 100ms (couldn't ) the frequency is 11.059200 the mc is used in x2 in the initialisation MOV T2MOD,#01H ; not sure about the DCEN register MOV RCAP2L,#?? MOV RCAP2H,#??? MOV TH2,#?? MOV TL2,#?? tmp400us EQU 32 SETB TR2 the interruption routine CPL P1.x ;any one CPL P1.z ; an other pin DJNZ cpm400us,RETI SETB CR ; démarage du timer de la PCA MOV cpm400us,#32 MOV RCAP2H,#00 ; to have a max time but never reach 100 ms CLR TF2 ; i'm not to do it or no each time RETI i write comments arount where i'm not sure. if some one could help i'll be gratefull thankx in advance
