Can I use ISD51 in the target system of at89c51? I tried it. But if I use the ISD51 debugger and select the debugger option"verify if the application in ROM is identical to current project", the connetion error will happen. otherwise,the debugger can connect to the target correctly. Any solutions or suggestions? Best regards Lakeshu Hu
Which communication error?
Thanks for your help. lakeshu hu
