Why can the code size be zero?
CTEST   MACRO
        REPT    4095
                SJMP $
                SJMP $
                SJMP $
                SJMP $
                SJMP $
                SJMP $
                SJMP $
                SJMP $
        ENDM
        ENDM
        CSEG    AT 0x0000
CODE_START:
        CTEST
        SJMP $
        SJMP $
        SJMP $
        SJMP $
        SJMP $
        SJMP $
        SJMP $
        SJMP $
CODE_END:
        END
The corresponding .lst shows:
A51 MACRO ASSEMBLER  CTEST        05/24/2004 15:16:34 PAGE     1
MACRO ASSEMBLER A51 V7.04
OBJECT MODULE PLACED IN CTEST.OBJ
ASSEMBLER INVOKED BY: C:\KEIL\C51\BIN\A51.EXE CTEST.asm SET(SMALL) DEBUG EP
LOC  OBJ            LINE     SOURCE
                       1     ;***********************************
                       2     CTEST   MACRO
                       3             REPT    4095
                       4                     SJMP $
                       5                     SJMP $
                       6                     SJMP $
                       7                     SJMP $
                       8                     SJMP $
                       9                     SJMP $
                      10                     SJMP $
                      11                     SJMP $
                      12             ENDM
                      13             ENDM
                      14     ;***********************************
                      15
----                  16             CSEG    AT 0x0000
0000                  17     CODE_START:
                      18             CTEST
FFF0 80FE          32789             SJMP $
FFF2 80FE          32790             SJMP $
FFF4 80FE          32791             SJMP $
FFF6 80FE          32792             SJMP $
FFF8 80FE          32793             SJMP $
FFFA 80FE          32794             SJMP $
FFFC 80FE          32795             SJMP $
FFFE 80FE          32796             SJMP $
0000               32797     CODE_END:
                   32798             END
The corresponding .m51 file shows:
BL51 BANKED LINKER/LOCATER V5.02                                                        05/24/2004  15:16:35  PAGE 1
BL51 BANKED LINKER/LOCATER V5.02, INVOKED BY:
C:\KEIL\C51\BIN\BL51.EXE CTEST.obj TO CODE_TEST RAMSIZE (256)
INPUT MODULES INCLUDED:
  CTEST.obj (CTEST)
LINK MAP OF MODULE:  CODE_TEST (CTEST)
            TYPE    BASE      LENGTH    RELOCATION   SEGMENT NAME
            * * * * * * *   D A T A   M E M O R Y   * * * * * * *
            REG     0000H     0008H     ABSOLUTE     "REG BANK 0"
            * * * * * * *   C O D E   M E M O R Y   * * * * * * *
            CODE    0000H     0000H     ABSOLUTE
  • Hi,
    it is just a bug of Keil.
    For example, next code:
            CSEG    AT 0x0000
    CODE_START:
    	SJMP	$
    	DS	65533
            END
    reports about code size 65535,
    next example:
            CSEG    AT 0x0000
    CODE_START:
    	SJMP	$
    	DS	65534
            END
    reports about code size 0 although it must be 65536. I think they easy fix it at next update with extending code_size variable type from 16-bit (uword) to 32-bit value (ulong).
    Regards,
    Oleg
    the thing I cannot understand:
  • Hi,
            CSEG    AT 0x0000
    CODE_START:
    	SJMP	$
    	DS	65533
            END
    next example:
            CSEG    AT 0x0000
    CODE_START:
    	SJMP	$
    	DS	65534
            END
    Regards,
    Oleg
