how to operate the 128byte page divided memory up to 1K in c51 like Hynix HMS9xc8032? In HMS9xc8032,the data memory is divided into 8 page(2 SFR page),SFR is also have a little different with standard 8051,but in this web,support a reg52.h header file only. So,anyone can tell us how to operate the data memory?Best is that someone can offer the source code or application notes. Thanks and Best Regards!
I think your best bet is to look at the XBANKING memory support. I couldn't figure out from the data sheet if the additional DATA memory is indirectly addressable or not. If it isn't, then you can't use XBANKING--you'll have to figure something out on your own. The data sheet was pretty clear on how to switch data pages. Re-read the data sheet and it will be obvious. Jon
Thank you for your reply! Should be my qustion is which data type can assign the data in keil c51 for this case? If write it in asm,there is OK according the data sheet. So,my question is how to assign the data type?Can you give us an example,please! Thanks!
