scanf error when code is > 64K
Hallo,
I face another problem:
I am using Cx51 Ver 7.06
I am using Philips/89C669
I am using ROM(HUGE) (code size maybe > 64K)
I use number of sscanf functions and
until now everything was fine.
Now my code size actually grew more than
64K and then I get this error:
*** ERROR L121: IMPROPER FIXUP
    MODULE:  C:\KEIL\C51\LIB\CS51FPS.LIB (SCANF)
    SEGMENT: ?PR?SCANF?SCANF
    OFFSET:  000043H
If I take out some lines in the program
(not sscanf, but any other lines),
such that code is again < 64K, then I get
no error. Which means the error is not
due to sscanf function but due to code
size (It is my guess :)
What should I do now? I am not possible
to reduce any code. I am still not completely
written the prgram, which means the code
size will increase even more.
mk
