how to define a byte variable in bit addressing space in assembly
There is am assembly file that will be integrated into my project that is written in c. A variable defined in the assembly file as
PROCTOCOL  equ  020H
I converted it to
RSEG ?BI?RunIsp?ISP
?RunIsp?BIT:
PROTOCOL:  DBIT  8
The compiler gave me two errors:
1. DATA-ADDRESS EXPECTED
2. INVALID BYTE BASE IN BIT ADDRESS EXPRESSION
The first error was caused by
MOV	PROTOCOL, #0
and the second error was caused by
SETB	PROTOCOL^1
How should I define PROTOCOL to make it work in c environment? Thank you for answering my question.
chao.
