MONITOR ERROR 6: CANNOT WRITE BREAKPOINT
Sometimes, when I load uV2 and start the debugger and press F5 (run) I get this error message:
When this happens, the program is not running, but if I press F5 again, all is well. I don't disable the global interrupt enable (IEN) anywhere in my app. I can set breakpoints anywhere in my app (after main() is called from the startup ASM code) and the debugger seems to work just fine. Every time I exit and re-enter the debugger (usually with a re-build in between) and restart debugging, I no longer get the error message. Anyone know why I might be getting the error message just once, not always, but when I get it, it's always right after I start debugging right after starting uV2?
I've tried to find ways to make it repeatable, like pressing RESET, cycling power, exiting and re-entering uV2, in various combinations and sequences, but I can't seem to make it repeatable. It does seem to happen every time I start debugging with uV2 for the first time each day.
I don't think there's anything unusual about my pcb hardware. It's pretty standard... flash ROM at CS0-, shadow RAM (for the debugger) at CS1-, and program RAM at CS2-. There's no glue logic on the bus, although I do have a DUART (Philips SC26C92) on CS3-.
Don't know if this matters or not, but I'm using the debugger in BSL mode, and based my project on the Phytec KC167CR sample monitor and BLINKY projects.
Curious...
Dave.
  • Hi Dave,
    today I had this problem too. After hours of spending time I found one solution for me that worked: Deleting the projects .opt file let the error disappear.
    The situation was: I had a project on a c164 target board with RAM from 0x00000-0x20000. Downloading Firmware to RAM and debugging with MON166 was always possible. From now to then the "MONITOR ERROR 6: CANNOT WRITE BREAKPOINT" appeard. My CVS showed no relevant changes. But the older project spapshots did work. So the solution was deleting the option file.
    best regards
  • Hi Dave,
    best regards
