help.
I receive lots of the following error messages when I link my program using RTx51:
*** Warning L1: Unresolved External Symbol
Symbol: ?RTX_MBX_PAGE
MODULE: C:\keil\C51\Lib\RTX51.LIB(RTXINIT)
Anyone can kindly help me to solve this problem?
Thank you in advance.
  • I'm not an RTX51 user, so my ability to help is limited. But I'll take a stab at it since it's the weekend.
    The error message means that the RTX51 library code is looking for the symbol RTX_MBX_PAGE, and can't find it. From the name, this symbol looks like it has to do with mailbox configuration -- the page of memory in which the mailboxes reside, perhaps.
    There should be an assembler file that you have to configure to match your preferences for the OS. (RTXCONF.A51, is it? Something like that.) I expect that you need to make a copy of this file, include it in your project so that it gets built, and link the resulting object code with your project so that RTX_MBX_PAGE is defined for the linker. Also, check the options to be sure that the mailbox option is enabled (assuming it is optional).
Reply Children
