my problem is how to use malloc or free function in interrupt function,because the function like malloc() or free() is non_reentrant.But i have to do it in interrupt function to save memory. what shall i do? please help me! i use timer0 to free the memory when memeory is no applied,but after three times,the timero is closed auto. the warning is: multi call to a segment free() or malloc(); i describe my algorithm as below: 1)i make the data to link list firstly; 2)in timer0, i will write the node of the link list to CAN bus buffer, after it ,i will free the node.but the timer0 just work 3 times,when it gets the fourth ,the timer0 is closed auto, what shall i do?? regards!! thanks !!
See the following pseudo codes...
void *MyMalloc (size_t s) { void *p; DisableISR; p=malloc(s); EnableISR; retrun p; } void MyFree (void *p) { DisableISR; free(p); EnableISR; } int main (void) { p=MyMalloc(x);//malloc(). ... MyFree(p);//free(). } void ISRxx (void) { p=malloc(x); ... free(p); }
or look at the DISABLE pragma - see the Manual
