hi: /* these codes are about DS1244. I can make sure the circuit is correct because I can access data from DS1244 correct . but I can't use Phantom Real-Time Clocks. when I try to get the data of Time register, I get all zero ,Thank you for you reply*/
#include "reg51.h" #include "absacc.h" static char xdata * data wdata; unsigned char code DSdata[8] = {0xC5,0x3A,0xA3,0x5C,0xC5,0x3A,0xA3,0x5C}; unsigned char code settime[8] = {0x00,0x00,0x00,0xB2,0x14,0x27,0x08,0x03}; sbit P10 = P1^0; sbit P11 = P1^1; void gettime(unsigned char x[]); void setuptime(void); void initime(void) ; main() { /////////////////////////// unsigned char CurrentTime[8]; P1 = 0xFF; if ( P10 ==0) { initime(); setuptime(); } if ( P11 == 0) { initime(); gettime(CurrentTime); // ALL THE DATA OF CurrentTime are zero.; } } void gettime(unsigned char x[]) { unsigned char i,loop,temp,dat; bit D0; wdata = 0xF0FF; for ( i = 0 ; i < 8 ; i++) { dat = 0; for ( loop = 0 ; loop < 8 ; loop++) { temp = * wdata; D0 = temp & 0x01; if(D0) dat = dat | 0x80; dat = dat>>1; } x[i] = dat; } } /*888888888888888888888888888888888888888888888888888*/ void setuptime(void) { unsigned char i,loop,temp,dat; bit D0; wdata = 0xF0FF; for ( i = 0 ; i < 8 ; i++) { temp = settime[i]; for ( loop = 0 ; loop < 8 ; loop++) { D0 = temp & 0x01; dat = (char)D0; *wdata = dat; temp = temp>>1; } } } /*8888888888888888888888888888888888888888888888888888888888*/ void initime(void) { unsigned char i,loop,temp,dat; //bit D0; wdata = 0xF0FF; for ( i = 0 ; i < 64 ; i++) temp = *wdata; for ( i = 0 ; i < 8 ; i++) { temp = DSdata[i]; for ( loop = 0 ; loop < 8 ; loop++) { dat = temp >>loop; *wdata = dat; } } }
