Hi all i want to read RTC time parameters. RTC is treated as one of memory location,it gets enabled when parameters are refered. following where the codes:
struct tm{ unsigned char xdata second _at_(0xe000); unsigned char xdata minute _at_(0xe002); unsigned char xdata hour _at_(0xe004); }; void main() { struct tm time; printf("seconds %x",time.second) ... }
struct tm{ unsigned char second _at_(0xe000); }
xdata unsigned char second _at_(0xe000); xdata unsigned char minute _at_(0xe002); xdata unsigned char hour _at_(0xe004); void main() { printf("\nseconds %x",second); printf("\nminutes %x",minutes); printf("\nhours %x",hour); }
struct tm{ unsigned char xdata second _at_(0xe000); unsigned char xdata minute _at_(0xe002); unsigned char xdata hour _at_(0xe004); }; void main() { struct tm time1,time2; ......
What you need is:
struct tm { unsigned char second; unsigned char res1; unsigned char minute; unsigned char res2; unsigned char hour; }; struct tm xdata time _at_ 0xe000; // time starts at 0xe000 !! void main() { }
"You can specifiy addresses for variables and structures/unions - not for structure elements." Yes, I was surprised that he seemed to be suggesting that the compiler accepted _at_ within a structure definition!!?? Does it really????
"Yes, I was surprised that he seemed to be suggesting that the compiler accepted _at_ within a structure definition!!?? Does it really????" The compiler ignores the _at_ statement applied to structure elements! There is no compile error - I have tried it with V7.06a. The compiler calculates the addresses of structure elements from the beginning of the structure - and this is not 0xe000
