Hi there, I need to program a P89LPC932 already soldered on a board. I found an application note from philips that shows this procedure. It requires a chip called MAX3322. Unfortunately, this chip cannot be found. Is there any other way of doing this? Could I used the MAX563CWN that is included in the MCB900 eval-board instead? Thank you.
