I always get an error 129 (missing ';' before 'void') when I compile in this part: func void iicstart (void) { sda = 1; scl = 1; del4us () sda = 0; del4us () scl = 0; del4us () } what is wrong?
On second look, it appears you have debugger functions confused with C functions. When writing your C program, you must use ANSI C rules. And, func is not a part of that rule set. If your function is intended to be used in your program, you should modify it as follows:
void iicstart (void) { sda = 1; scl = 1; del4us (); sda = 0; del4us (); scl = 0; del4us (); }
func void iicstart (void) { sda = 1; scl = 1; del4us (); sda = 0; del4us (); scl = 0; del4us (); }
