Anybody familiar with the 251-architecture? I'm using an INTEL 80c251 running in "PAGE MODE". Page mode is used to speed-up the code fetching from external memory, and have an effect on the ALE-signal operation wich controls the multiplex- function(74573) of the external data/address bus. I waste no more time to explain the details of this mode because if there is any interest in the subject one probably already know the details, but if not it can be found in the 80c251 user's manual and in INTEL's appnot AP-710. In my 8051-constructions I use the ALE-signal to kick on a peripheral watchdog(MAX1232) when I don't want to do it from the program via a port- pin.(Normaly this rarely happends, yet a hardware strappingchoice exist). Here is the ALE-signal always generated and the watchdog will never activate the reset(in normal conditions). If I use a 80c251 in the same manner, but with the page mode design I see a theoretical risk that the watchdog(MAX1232) timer will run out and reset the device(80c251). If the code fetching stays in the same page(256 bytes) the ALE-signal is not generated. And if it stays there long time enough the reset will therefore be activated. Even if I think the chance is small, I don't think the design with ALE- signal and watchdog(MAX1232) is 100% waterproof in this case. If anyone has any knowledge,experience or has come to the same conclusion as I in this problem I would appreciate an answer.
Yep. That sounds right to me. Using ALE to reset the watchdog sounds dangerous, but I understand why you are doing it. Maybe using one of the data or address lines (like A0 to reset the watchdog) is a better itea. Jon
This use of the ALE goes against what I was always taught to be the "philosophy" behind the watchdog timer. The timer was to be reset only by the user code in order to provide protection against things like program counter corruption, infinite loops, etc.
Jon, thank you for your confirming and suggestion. Barry, you have absolutely right. Regards, Pelle
