We are using Keil C-51 V7.06. There is a structure defined:
typedef struct { unsigned char address_bus_h; unsigned char address_bus_l; unsigned char data_bus; }instbus_raw_t;
instbus_raw.address_bus_h = instbus_raw_local.address_bus_h; instbus_raw.address_bus_l = instbus_raw_local.address_bus_l; instbus_raw.data_bus = instbus_raw_local.data_bus;
memcpy(&instbus_raw,&instbus_raw_local,sizeof(instbus_raw_t));
void *(my_memcpy)(void *s1, const void *s2, size_t n) { char *su1 = (char *)s1; const char *su2 = (const char *)s2; for (; 0 < n; --n) *su1++ = *su2++; return (s1); } my_memcpy(&instbus_raw,&instbus_raw_local,sizeof(struct instbus_raw_t));
Does anyone remarking same effects with library functions wasting resources? There's always a trade-off with vendor-provided library routines. And, no matter HOW we implemented a routine, someone would be unhappy. The memcpy routine in the library contains a subroutine for every memory space. When memcpy runs it first figures out the source memory type and the destination memory type and calls the appropriate routine (there is a routine for data to data, data to xdata, code to data, xdata to xdata, and so on). Each of these routines uses registers and is optimized for speed. Of course, there is a size penalty. The memcpy you provide executes very slowly. It uses generic pointers (3-bytes) that are stored in the default memory space (XDATA in large model). Each read and each write requires a function call into the C runtime library. However, if you only need to copy something once or if you don't need a high-speed routine, this is probably just fine. Jon
One more thing. The my_memcpy is not reentrant (the one in the library is). So, be sure you don't invoke it from the main program and an interrupt. Jon
Here is a compact version of memcpy() that is reenterant and is reasonably fast given its size. compact_memcpy.c:
#include "compact_memcpy.h" // // Compact Memory Copy // // Author: Graham Cole // // This function compies n bytes from s2 to s1. // // The address of memory block is a Keil generic pointer in R1/R2/R3. // // R1 - low part of address. // R2 - high part of address. // R3 - memory type where: // // The address of memory block s2 is a Keil generic pointer in R0/R4/R5. // // R0 - low part of address. // R4 - high part of address. // R5 - memory type where: // // The value of s2 is loaded from parameter passing memory. // // Where memory type is as follows: // // 0x00 - indicates idata memory. // 0x01 - indicates xdata memory. // 0xFE - indicates pdata memory. // 0xFF - indicates code memory. // // The value of n is held in registers R6/R7. // // The first lines of C code will suppress the UNUSED variable warning and the // Keil C51 compiler will optimise this code out. The return() statement is // compiled to an unused RET instruction. // #pragma ASM $REGUSE _compact_memcpy( A, B, PSW, DPH, DPL, R0, R1, R2, R3, R4, R5, R7 ) #pragma ENDASM void *compact_memcpy(void *s1, void *s2, int n) { s1 = s1; //Suppress UNUSED s2 = s2; //Suppress UNUSED n = n; //Suppress UNUSED #pragma ASM ; EXTRN CODE( primary_generic_write ) ; EXTRN CODE( auxilliary_generic_read ) ; ; MOV R5,s2?041+00H ;Load s2 into registers. MOV R4,s2?041+01H ;(auxilliary generic pointer) MOV R0,s2?041+02H ; ; MOV R6,n?042+00H ;Load n into registers. MOV R7,n?042+01H ; ; compact_memcpy: ; ; MOV s1?040+00H,R3 ;Save s1 into memory. MOV s1?040+01H,R2 ;(primary generic pointer) MOV s1?040+02H,R1 ; ; MOV A,R6 ; ORL A,R7 ; JZ ?compact_memcpy_generic_end ;If zero bytes to copy, terminate. ; INC R6 ;Pre increment n bytes for DJNZ. ; ?compact_memcpy_loop: ; ; CALL auxilliary_generic_read ;Read byte at pointer s2. CALL primary_generic_write ;Write byte to pointer s1. ; INC R1 ;Increment s1 generic pointer... CJNE R1,#0x00,?compact_memcpy_generic_skip_0 INC R2 ; ; ?compact_memcpy_generic_skip_0: ; ; INC R0 ;Increment s2 generic pointer... CJNE R0,#0x00,?compact_memcpy_generic_skip_1 INC R4 ; ; ?compact_memcpy_generic_skip_1: ; ; DJNZ R7,?compact_memcpy_loop ; DJNZ R6,?compact_memcpy_loop ;..and iterate. ; ?compact_memcpy_generic_end: ; ; MOV R3,s1?040+00H ;Restore s1 into registers. MOV R2,s1?040+01H ; MOV R1,s1?040+02H ; RET ; ; #pragma ENDASM return( 0 ); // Dummy return. }
And, of course, you will be needing this: compact_memcpy.h:
#ifndef _COMPACT_MEMCPY_H_ #define _COMPACT_MEMCPY_H_ void *compact_memcpy(void *s1, void *s2, int n); #endif
// // Primary Generic Read // // This function reads from a location defined by a generic pointer // // The arguments of the generic pointer are as follows: // // R1 - low part of address. // R2 - high part of address. // R3 - memory type where: // // 0x00 - indicates idata memory. // 0x01 - indicates xdata memory. // 0xFE - indicates pdata memory. // 0xFF - indicates code memory. // // This function is functionally identical to, and interchangable // with, the comiler function C?CLDPTR. // #pragma ASM PUBLIC primary_generic_read ?PR?primary_generic_read SEGMENT CODE RSEG ?PR?primary_generic_read primary_generic_read: MOV A,R3 ; JNB Acc.0,?pgr_not_dptr ; MOV DPL,R1 ; MOV DPH,R2 ; JB Acc.1,?pgr_not_xdata ; MOVX A,@DPTR ; RET ; ?pgr_not_xdata: ; CLR A ; MOVC A,@A+DPTR ; RET ; ?pgr_not_dptr: ; JNB Acc.1,?pgr_not_pdata ; MOVX A,@R1 ; RET ; ?pgr_not_pdata: ; MOV A,@R1 ; RET ; #pragma ENDASM // // Primary Generic Write // // This function writes accumulator to a location defined by a generic pointer // // The arguments of the generic pointer are as follows: // // R1 - low part of address. // R2 - high part of address. // R3 - memory type where: // // 0x00 - indicates idata memory. // 0x01 - indicates xdata memory. // 0xFE - indicates pdata memory. // 0xFF - indicates code memory. // #pragma ASM PUBLIC primary_generic_write ?PR?primary_generic_write SEGMENT CODE RSEG ?PR?primary_generic_write primary_generic_write: MOV B,R3 ; JNB B.0,?pgw_not_dptr ; MOV DPL,R1 ; MOV DPH,R2 ; JB B.1,?pgw_not_xdata ; MOVX @DPTR,A ; RET ; ?pgw_not_xdata: ; RET ; ?pgw_not_dptr: ; JNB B.1,?pgw_not_pdata ; MOVX @R1,A ; RET ; ?pgw_not_pdata: ; MOV @R1,A ; RET ; #pragma ENDASM // // Auxilliary Generic Read // // This function reads from a location defined by a generic pointer // // The arguments of the generic pointer are as follows: // // R0 - low part of address. // R4 - high part of address. // R5 - memory type where: // // 0x00 - indicates idata memory. // 0x01 - indicates xdata memory. // 0xFE - indicates pdata memory. // 0xFF - indicates code memory. // #pragma ASM PUBLIC auxilliary_generic_read ?PR?auxilliary_generic_read SEGMENT CODE RSEG ?PR?auxilliary_generic_read auxilliary_generic_read: MOV A,R5 ; JNB Acc.0,?agr_not_dptr ; MOV DPL,R0 ; MOV DPH,R4 ; JB Acc.1,?agr_not_xdata ; MOVX A,@DPTR ; RET ; ?agr_not_xdata: ; CLR A ; MOVC A,@A+DPTR ; RET ; ?agr_not_dptr: ; JNB Acc.1,?agr_not_pdata ; MOVX A,@R0 ; RET ; ?agr_not_pdata: ; MOV A,@R0 ; RET ; #pragma ENDASM
...actually, compact_memcpy() is not reenterant.
Many Thanks for your postings! The routine that we are needing, has to be reentrant. In our project, the chip does only have DATA and memcpy has to copy same bytes from DATA to DATA.
Then you will be wanting something like this:
// // Data Memory Copy // // Author: Graham Cole // // This function compies n bytes from s2 to s1. // // The address of memory block s1 is a Keil generic pointer in R7. // // The address of memory block s2 is a Keil data pointer in R5. // // The value of n is held in registers R3. // // The first lines of C code will suppress the UNUSED variable warning and the // Keil C51 compiler will optimise this code out. The return() statement is // compiled to an unused RET instruction. // #pragma ASM $REGUSE _data_memcpy( A, PSW, R0, R1, R3 ) #pragma ENDASM char data *data_memcpy(char data *s1, char data *s2, unsigned char n) { s1 = s1; //Suppress UNUSED s2 = s2; //Suppress UNUSED n = n; //Suppress UNUSED #pragma ASM ; data_memcpy: ; ; MOV A,R7 ;Load s1 into register R0. MOV R0,A ; MOV A,R5 ;Load s2 into register R1. MOV R1,A ; ; MOV A,R3 ; JZ ?data_memcpy_generic_end ;If zero bytes to copy, terminate. ; ?data_memcpy_loop: ; ; MOV A,@R1 ;Read from pointer s2. MOV @R0,A ;Write to pointer s1. ; INC R1 ;Increment s2 pointer. INC R0 ;Increment s1 pointer. ; ?data_memcpy_generic_skip_1: ; ; DJNZ R3,?data_memcpy_loop ;..and iterate. ; ?data_memcpy_generic_end: ; ; ;Return with s1 still in R7. RET ; ; #pragma ENDASM return( 0 ); // Dummy return. }
For a bit of amusement I compiled the following code under v7.01 optimisation level 9:
unsigned char data *my_data_memcpy(unsigned char data *dest, unsigned char data *src, unsigned char n) { unsigned char data *temp=dest; while(n) { *temp=*src; temp++; src++; n--; } return(dest); }
Ah, yes, sometime I just cannot helpmyself from getting into assembler... In fact, the C version could probably be slightly improved by using
do { ... }while(--n != 0);
"Finally I also noticed that the return(0); in Graham's function generates a MOV R7,#00H instruction as well as a RET, which is a shame." Like I always say: if you need some assembler, have it properly as an assembler module - don't mess about with inline assembler in 'C' source files! Graham's function actually contains four lines whose sole function is to suppress compiler warnings. Luckily, the compiler happens to be smart enough to spot that the 1st three are irrelevant, and optimises them out. That just leaves the "spurious" RET. Using the SRC directive is a great way to create 'C'-compatible assembler source - with all the right calling & naming conventions, parameter passing, etc - but once you've done that, the 'C' file is of no further use; so throw it away!
Maybe a bit off topic, but I just wanted to share a thought. Take a look at the webpage of a new programming language called D: http://www.digitalmars.com/d/overview.html Here is a quote: Modern compiler technology has progressed to the point where language features for the purpose of compensating for primitive compiler technology can be omitted. (An example of this would be the 'register' keyword in C, a more subtle example is the macro preprocessor in C.) We can rely on modern compiler optimization technology to not need language features necessary to get acceptable code quality out of primitive compilers. Yet a lot of discussions around the use of C in microcontroller programming boil down to how to get more optimal code from a particular C compiler. Is it that Keil's compilers have not caught up with the latest and greatest in compiler technology? Or am I too picky? - mike
Is it that Keil's compilers have not caught up with the latest and greatest in compiler technology? Can you give me an example (manufacturer and version) of a compiler that is the latest and greated in technology. That way, I can let you know if we've caught up with them. Jon
"Or am I too picky?" You're too picky. In my opinion: If you have to use assembler rather than 'C' for reasons of code size or speed then you're using the wrong hardware. The only case I can really see for using assembler is when you need to make sure the code doesn't change across compiler versions.
Yes, I agree, statements like these have to be supported by facts. I use the C166 compiler, and there are not too many compilers for that architecture. And from what I heard Keil's C166 is the best available. But what I meant was that so many times when I look at the code generated by C166 I can't help but notice so obvious optimizations not performed by the compiler. Let's look at a real-world example:
#include <intrins.h> long l[2]; long read_long_atomically(int i) { long tmp; long *ptr; ptr = &l[i]; _atomic_(0); tmp = *ptr; _endatomic_(); return tmp; } Compiler listing: MOV R5,R8 SHL R5,#02H MOV R4,#l ADD R4,R5 ATOMIC #02H MOV R6,[R4] MOV R7,[R4+#02H] MOV R4,R6 MOV R5,R7 RET
SHL R8,#4 ADD R8,#l ATOMIC #02H MOV R4,[R8] MOV R5,[R8+#2] RET
In this case, I agree with you. However, most functions are not quite that trivial. It's easy to create the perfect optimizing compiler if you guarantee that all function it compiles are small and are not too complex. The problem arises when you have functions that are insanely complex. Then, the compiler still must do a good job. As it is, the small functions like you demonstrate would be the ones that I would first write in C (to get working) and later go back in write in assembly (if needed). Jon
"If you have to use assembler rather than 'C' for reasons of code size or speed then you're using the wrong hardware." As I've said before, all generalisations are bad! ;-) IF you are making extremely cheap products in extremely large volumes, the development costs are secondary to the component costs. In such cases, you want the cheapest processor you can possibly find - and you can afford to put in a bit more development effort to squeeze the last ounce of performance, or shoe-horn the code into the smallest possible ROM. However, I do agree that most of the questions here about inline assembler are due to misconceptions...
The only case I can really see for using assembler Sometimes you need to poke around in assembler for some glue logic in startup code before main can even get going. Say, boot code loading an application and restarting into it, or initializing bank switch logic, or that sort of thing. C presumes a certain environment exists, and somethings you need to do things outside of that world's "laws of physics". Other times, you might need assembler to cope with some picky hardware. C doesn't always give you precise control over which bits change at which address on which clock cycle. Speed and efficiency count, too. Often, there's just a couple of routines that can greatly benefit from specialized assembler, and just throwing a bigger processor at the whole project for the sake of a couple of functions is not really the right answer.
