Hi, I am developing a firmware for EZUSB FX based board. I am facing a small problem. I am not able to initialize a Global variable in my firmware. Even though I assign the global variable with 0 initial value, But the variable does not take that value. I am using SMALL memory model for my development. my declerations looks like this :- BYTE GlobalCount = 0; and in my sof() I am using this variable and updating it and reusing it again in next sof(). Please advise .. Rahul Gupta
Since GlobalCount is declared as follows:
Hi, 1) Memory model is small 2) My initialization is BYTE GlobalCount = 0; So, DO I have to clear XDATA in my STARTUP code.(I am not using xdata here) I am a beginner on 8051, So I might be making very basic mistake. Please Advise ... Thanks Rahul
So, DO I have to clear XDATA in my STARTUP code.(I am not using xdata here) If you're not using XDATA, then, NO. Here's what I'd do. 1. In uVision, open your project options and do to the debug tab. Uncheck go til main under the simulation side (left side). Make sure the simulator radio button (top left) is checked. 2. Start the debugger. 3. Set a memory access breakpoint on GlobalCount. Type the following in the Command Window: bs readwrite GlobalCount. 4. Run the program. Execution stops when anything reads or writes to GlobalCount. The first place that program execution stops should be in the startup code (because that clears all data memory to 0). Jon
I got the debugging thing and this is what I have found. 1) GlobalCount is initialized to 0 in my startup code, main(), and even in TD_POLL(polling function). 2) But in SOF() (interrupt routine) it was not zero and had some garbage value..... I couldn't verify this in simulation mode (I guess simulation mode does not support interrupts). My problem is I want this global to be 0 in my SOF() (interrupt routine) for the first time and then update it, so that it is again available in next SOF interrupt. ?? TIA Rahul
Reduce your code to the minimum complete program that exhibits the problem then post it here.
GlobalCount is initialized to 0 in my startup code, main(), and even in TD_POLL(polling function). Sounds like the compiler and startup code are doing their jobs. But in SOF() (interrupt routine) it was not zero and had some garbage value. Sounds like it's getting trashed somewhere else in your program. Jon
here is the relevant code ... I have included init.A51 and STARTUP.A51 in the project in that order. static BYTE glbCount = 0; // global //Interrupt Routine void ISR_Sof(void) interrupt 0 { BYTE i = 0; for (i=0;i<16;i++) { IN8DATA = glbCount; } glbCount = glbCount + 0x10; EZUSB_IRQ_CLEAR(); USBIRQ = bmSOF; // Clear SOF IRQ } Now this ISR_SOF() starts with some arbit value and increment by 0x10 as desired. Interestingly, When glbCount is initialized with 0 the values returned by the Firmware (IN8DATA) are 20, 30 ,40... (i.e. the LS-nibble is 0) while if I initialize glbCount by 2 the values returned are 22, 32, 42 .. etc (i.e. the LS-nibble is 2). P.S. - the values 20, 30 . is an example, As I have told you initial value is garbage. Please Advise.. Thanks Rahul Gupta
As, in code Posted above I never touch the GlobalCount in any of my functions. There should be any corruption. Is there any other way I can achieve the desiref functionality ??? Thanks Rahul Gupta
oops! it's really bad! :-( :-( try to understand where this memory location was overwrited. 1. Check .m51, where var is located. 2 is there any array before or after this var? array index may be wrong, for example char x[7]; x[i]= 0; with i>= 7; use x[8] and x[i&7] instead, especially for receiver buffer! 3 did you use any pointer operation, like char *x; *x= value; x may be wrong. 4 did you use sprintf ? If format is wrong, it may put data outside the buffer
On Analysing the problem further, This is the behaviour I have observed .... If I remove the code line viz. glbCount = glbCount + 0x10; in the Code attached below. The glbCount is initialized to 0. But if this line of code is there then I my glbCount can start It seems this particular line of code is corrupting the Initial value. If it is ... what is the alternate way to achieve the desired functionality ??? TIA Rahul Gupta static BYTE glbCount = 0; // global //Interrupt Routine void ISR_Sof(void) interrupt 0 { BYTE i = 0; for (i=0;i<16;i++) { IN8DATA = glbCount; } glbCount = glbCount + 0x10; EZUSB_IRQ_CLEAR(); USBIRQ = bmSOF; // Clear SOF IRQ }
On Analysing the problem further, This is the behaviour I have observed .... If I remove the code line viz. glbCount = glbCount + 0x10; in the Code attached below. The glbCount is initialized to 0. But if this line of code is there then the glbCount can take any garbage value and increment subsiquently ... It seems this particular line of code is corrupting the Initial value. If it is ... what is the alternate way to achieve the desired functionality ??? Attaching code for reference ... Please Advise !! static BYTE glbCount = 0; // global //Interrupt Routine void ISR_Sof(void) interrupt 0 { BYTE i = 0; for (i=0;i<16;i++) { IN8DATA = glbCount; } glbCount = glbCount + 0x10; EZUSB_IRQ_CLEAR(); USBIRQ = bmSOF; // Clear SOF IRQ }
Reduce your code to the minimum complete program that exhibits the problem then post it here. Until then we are fishing in the dark.
here is the code ..
//FW.C #include "ezusb.h" #include "ezregs.h" //----------------------------------------------------------------------------- // Global Variables /----------------------------------------------------------------------------- volatile BOOL GotSUD; BOOL Rwuen; BOOL Selfpwr; volatile BOOL Sleep; WORD pDeviceDscr; // Pointer to Device Descriptor; Descriptors may be moved WORD pConfigDscr; WORD pStringDscr; extern BYTE glbCntW; // Code -- // Task dispatcher void main(void) { DWORD i; WORD offset; DWORD DevDescrLen; DWORD j=0; WORD IntDescrAddr; WORD ExtDescrAddr; Sleep = FALSE; Rwuen = FALSE; Selfpwr = FALSE; GotSUD = FALSE; // Initialize user device TD_Init(); pDeviceDscr = (WORD)&DeviceDscr; pConfigDscr = (WORD)&ConfigDscr; pStringDscr = (WORD)&StringDscr; if ((WORD)&DeviceDscr & 0xe000) { IntDescrAddr = INTERNAL_DSCR_ADDR; ExtDescrAddr = (WORD)&DeviceDscr; DevDescrLen = (WORD)&UserDscr - (WORD)&DeviceDscr + 2; for (i = 0; i < DevDescrLen; i++) *((BYTE xdata *)IntDescrAddr+i) = 0xCD; for (i = 0; i < DevDescrLen; i++) *((BYTE xdata *)IntDescrAddr+i) = *((BYTE xdata *)ExtDescrAddr+i); pDeviceDscr = IntDescrAddr; offset = (WORD)&DeviceDscr - INTERNAL_DSCR_ADDR; pConfigDscr -= offset; pStringDscr -= offset; } EZUSB_IRQ_ENABLE(); // Enable USB interrupt (INT2) EZUSB_ENABLE_RSMIRQ(); PORTCCFG |= 0xc0; USBBAV = USBBAV | 1 & ~bmBREAK; USBIEN |= bmSUDAV | bmSUTOK | bmSUSP | bmURES; EA = 1; #ifndef NO_RENUM EZUSB_Discon(TRUE); // Renumerate #endif CKCON = (CKCON&(~bmSTRETCH)) | FW_STRETCH_VALUE; // Set stretch to 0 (after renumeration) // Task Dispatcher while(TRUE) // Main Loop { if(GotSUD) // Wait for SUDAV { SetupCommand(); // Implement setup command GotSUD = FALSE; // Clear SUDAV flag } if (Sleep) { if(TD_Suspend()) { Sleep = FALSE; do { EZUSB_Susp(); } while(!Rwuen && EZUSB_EXTWAKEUP()); EZUSB_Resume(); // If source is the Wakeup# pin, signal the host to Resume. TD_Resume(); } } TD_Poll(); } } void SetupCommand(void) { void *dscr_ptr; DWORD i; switch(SETUPDAT[1]) { case SC_GET_DESCRIPTOR: if(DR_GetDescriptor()) switch(SETUPDAT[3]) { case GD_DEVICE: SUDPTRH = MSB(pDeviceDscr); SUDPTRL = LSB(pDeviceDscr); break; case GD_CONFIGURATION: // Configuration if(dscr_ptr = (void *)EZUSB_GetConfigDscr(SETUPDAT[2])) { SUDPTRH = MSB(dscr_ptr); SUDPTRL = LSB(dscr_ptr); } else EZUSB_STALL_EP0(); // Stall End Point 0 break; case GD_STRING: // String if(dscr_ptr = (void *)EZUSB_GetStringDscr(SETUPDAT[2])) { STRINGDSCR *sdp; BYTE len; sdp = dscr_ptr; len = sdp->length; if (len > SETUPDAT[6]) len = SETUPDAT[6]; //limit to the requested length while (len) { for(i=0; i<min(len,64); i++) *(IN0BUF+i) = *((BYTE xdata *)sdp+i); //set length and arm Endpoint EZUSB_SET_EP_BYTES(IN0BUF_ID,min(len,64)); len -= min(len,64); (BYTE *)sdp += 64; // Wait for it to go out (Rev C and above) while(EP0CS & 0x04) ; } EZUSB_SET_EP_BYTES(IN0BUF_ID,0); EP0CS = bmHS; } else EZUSB_STALL_EP0(); // Stall End Point 0 break; default: // Invalid request EZUSB_STALL_EP0(); // Stall End Point 0 } break; case SC_GET_INTERFACE: // *** Get Interface DR_GetInterface(); break; case SC_SET_INTERFACE: // *** Set Interface DR_SetInterface(); break; case SC_SET_CONFIGURATION: // *** Set Configuration DR_SetConfiguration(); break; case SC_GET_CONFIGURATION: // *** Get Configuration DR_GetConfiguration(); break; case SC_GET_STATUS: // *** Get Status if(DR_GetStatus()) switch(SETUPDAT[0]) { case GS_DEVICE: // Device IN0BUF[0] = ((BYTE)Rwuen << 1) | (BYTE)Selfpwr; IN0BUF[1] = 0; EZUSB_SET_EP_BYTES(IN0BUF_ID,2); break; case GS_INTERFACE: // Interface IN0BUF[0] = 0; IN0BUF[1] = 0; EZUSB_SET_EP_BYTES(IN0BUF_ID,2); break; case GS_ENDPOINT: // End Point IN0BUF[0] = EPIO[EPID(SETUPDAT[4])].cntrl & bmEPSTALL; IN0BUF[1] = 0; EZUSB_SET_EP_BYTES(IN0BUF_ID,2); break; default: // Invalid Command EZUSB_STALL_EP0(); // Stall End Point 0 } break; case SC_CLEAR_FEATURE: // *** Clear Feature if(DR_ClearFeature()) switch(SETUPDAT[0]) { case FT_DEVICE: // Device if(SETUPDAT[2] == 1) Rwuen = FALSE; // Disable Remote Wakeup else EZUSB_STALL_EP0(); // Stall End Point 0 break; case FT_ENDPOINT: // End Point if(SETUPDAT[2] == 0) { EZUSB_UNSTALL_EP( EPID(SETUPDAT[4]) ); EZUSB_RESET_DATA_TOGGLE( SETUPDAT[4] ); } else EZUSB_STALL_EP0(); // Stall End Point 0 break; } break; case SC_SET_FEATURE: // *** Set Feature if(DR_SetFeature()) switch(SETUPDAT[0]) { case FT_DEVICE: // Device if(SETUPDAT[2] == 1) Rwuen = TRUE; // Enable Remote Wakeup else EZUSB_STALL_EP0(); // Stall End Point 0 break; case FT_ENDPOINT: // End Point if(SETUPDAT[2] == 0) EZUSB_STALL_EP( EPID(SETUPDAT[4]) ); else EZUSB_STALL_EP0(); // Stall End Point 0 break; } break; default: if(DR_VendorCmnd()) EZUSB_STALL_EP0(); } // Acknowledge handshake phase of device request // Required for rev C does not effect rev B EP0CS |= bmBIT1; } void resume_isr(void) interrupt WKUP_VECT { EZUSB_CLEAR_RSMIRQ(); }
#pragma NOIV // Do not generate interrupt vectors #include <ezusb.h> #include <ezregs.h> #include <stdio.h> #include <stdlib.h> #include <string.h> #define DCM_SIZE 64 #define XBYTE ((unsigned char volatile xdata*) 0) extern BOOL GotSUD; extern BOOL Sleep; extern BOOL Rwuen; extern BOOL Selfpwr; BYTE Configuration; BYTE AlternateSetting; volatile BYTE glbISOCnt =0 ; volatile BYTE glbCnt=0; static BYTE glbCntW = 0; volatile BYTE iso_out_cnt =0; unsigned char *pBuffer; unsigned char *CntBuf; //----------------------------------------------------------------------------- // Task Dispatcher hooks //----------------------------------------------------------------------------- void TD_Init(void) // Called once at startup { USBIEN |= bmSOF + bmURES; INISOVAL = bmEP8; //+bmEP9; OUTISOVAL = bmEP8; IN8ADDR = 0x50; OUT8ADDR = 0x00; } void TD_Poll(void) // Called repeatedly while the device is idle { } BOOL TD_Suspend(void) // Called before the device goes into suspend mode { return(TRUE); } BOOL TD_Resume(void) // Called after the device resumes { return(TRUE); } //----------------------------------------------------------------------------- // Device Request hooks // The following hooks are called by the end point 0 device request parser. //----------------------------------------------------------------------------- BOOL DR_GetDescriptor(void) { return(TRUE); } BOOL DR_SetConfiguration(void) // Called when a Set Configuration command is received { Configuration = SETUPDAT[2]; return(TRUE); // Handled by user code } BOOL DR_GetConfiguration(void) // Called when a Get Configuration command is received { IN0BUF[0] = Configuration; EZUSB_SET_EP_BYTES(IN0BUF_ID,1); return(TRUE); // Handled by user code } BOOL DR_SetInterface(void) // Called when a Set Interface command is received { AlternateSetting = SETUPDAT[2]; return(TRUE); // Handled by user code } BOOL DR_GetInterface(void) // Called when a Set Interface command is received { IN0BUF[0] = AlternateSetting; EZUSB_SET_EP_BYTES(IN0BUF_ID,1); return(TRUE); // Handled by user code } BOOL DR_GetStatus(void) { return(TRUE); } BOOL DR_ClearFeature(void) { return(TRUE); } BOOL DR_SetFeature(void) { return(TRUE); } BOOL DR_VendorCmnd(void) { return(FALSE); } //----------------------------------------------------------------------------- // USB Interrupt Handlers // The following functions are called by the USB interrupt jump table. //----------------------------------------------------------------------------- // Setup Data Available Interrupt Handler void ISR_Sudav(void) interrupt 0 { GotSUD = TRUE; // Set flag EZUSB_IRQ_CLEAR(); USBIRQ = bmSUDAV; // Clear SUDAV IRQ } // Setup Token Interrupt Handler void ISR_Sutok(void) interrupt 0 { EZUSB_IRQ_CLEAR(); USBIRQ = bmSUTOK; // Clear SUTOK IRQ } void ISR_Sof(void) interrupt 0 { BYTE i = 0; BYTE h = 0 , l = 0; iso_out_cnt = 0; h = OUT8BCH; l = OUT8BCL; if (l) { iso_out_cnt = (WORD) h; iso_out_cnt <<= 8; iso_out_cnt += l; } iso_out_cnt = OUT8BCL; if (iso_out_cnt > 0) { glbISOCnt = iso_out_cnt; } if (iso_out_cnt) { } else { for (i=0;i<glbISOCnt;i++) { IN8DATA = glbCntW; } glbCntW = glbCntW + glbISOCnt; if (glbCntW == glbISOCnt * 4) { glbCntW = 0; } } EZUSB_IRQ_CLEAR(); USBIRQ = bmSOF; // Clear SOF IRQ } void ISR_Ures(void) interrupt 0 { EZUSB_IRQ_CLEAR(); USBIRQ = bmURES; // Clear URES IRQ } void ISR_Susp(void) interrupt 0 { Sleep = TRUE; EZUSB_IRQ_CLEAR(); USBIRQ = bmSUSP; } Along with these 2 files I am including ezusb.lib, USBJMP.obj, STATUP.A51, INIT.A51(provided by cypress). Rahul
///////Periph.c #pragma NOIV // Do not generate interrupt vectors #include <ezusb.h> #include <ezregs.h> #include <stdio.h> #include <stdlib.h> #include <string.h> #define DCM_SIZE 64 #define XBYTE ((unsigned char volatile xdata*) 0) extern BOOL GotSUD; extern BOOL Sleep; extern BOOL Rwuen; extern BOOL Selfpwr; BYTE Configuration; BYTE AlternateSetting; volatile BYTE glbISOCnt =0 ; volatile BYTE glbCnt=0; static BYTE glbCntW = 0; volatile BYTE iso_out_cnt =0; unsigned char *pBuffer; unsigned char *CntBuf; //----------------------------------------------------------------------------- // Task Dispatcher hooks //----------------------------------------------------------------------------- void TD_Init(void) // Called once at startup { USBIEN |= bmSOF + bmURES; INISOVAL = bmEP8; //+bmEP9; OUTISOVAL = bmEP8; IN8ADDR = 0x50; OUT8ADDR = 0x00; } void TD_Poll(void) // Called repeatedly while the device is idle { } BOOL TD_Suspend(void) // Called before the device goes into suspend mode { return(TRUE); } BOOL TD_Resume(void) // Called after the device resumes { return(TRUE); } //----------------------------------------------------------------------------- // Device Request hooks // The following hooks are called by the end point 0 device request parser. //----------------------------------------------------------------------------- BOOL DR_GetDescriptor(void) { return(TRUE); } BOOL DR_SetConfiguration(void) // Called when a Set Configuration command is received { Configuration = SETUPDAT[2]; return(TRUE); // Handled by user code } BOOL DR_GetConfiguration(void) // Called when a Get Configuration command is received { IN0BUF[0] = Configuration; EZUSB_SET_EP_BYTES(IN0BUF_ID,1); return(TRUE); // Handled by user code } BOOL DR_SetInterface(void) // Called when a Set Interface command is received { AlternateSetting = SETUPDAT[2]; return(TRUE); // Handled by user code } BOOL DR_GetInterface(void) // Called when a Set Interface command is received { IN0BUF[0] = AlternateSetting; EZUSB_SET_EP_BYTES(IN0BUF_ID,1); return(TRUE); // Handled by user code } BOOL DR_GetStatus(void) { return(TRUE); } BOOL DR_ClearFeature(void) { return(TRUE); } BOOL DR_SetFeature(void) { return(TRUE); } BOOL DR_VendorCmnd(void) { return(FALSE); } //----------------------------------------------------------------------------- // USB Interrupt Handlers // The following functions are called by the USB interrupt jump table. //----------------------------------------------------------------------------- // Setup Data Available Interrupt Handler void ISR_Sudav(void) interrupt 0 { GotSUD = TRUE; // Set flag EZUSB_IRQ_CLEAR(); USBIRQ = bmSUDAV; // Clear SUDAV IRQ } // Setup Token Interrupt Handler void ISR_Sutok(void) interrupt 0 { EZUSB_IRQ_CLEAR(); USBIRQ = bmSUTOK; // Clear SUTOK IRQ } void ISR_Sof(void) interrupt 0 { BYTE i = 0; BYTE h = 0 , l = 0; iso_out_cnt = 0; h = OUT8BCH; l = OUT8BCL; if (l) { iso_out_cnt = (WORD) h; iso_out_cnt <<= 8; iso_out_cnt += l; } iso_out_cnt = OUT8BCL; if (iso_out_cnt > 0) { glbISOCnt = iso_out_cnt; } if (iso_out_cnt) { } else { for (i=0;i<glbISOCnt;i++) { IN8DATA = glbCntW; } glbCntW = glbCntW + glbISOCnt; if (glbCntW == glbISOCnt * 4) { glbCntW = 0; } } EZUSB_IRQ_CLEAR(); USBIRQ = bmSOF; // Clear SOF IRQ } void ISR_Ures(void) interrupt 0 { EZUSB_IRQ_CLEAR(); USBIRQ = bmURES; // Clear URES IRQ } void ISR_Susp(void) interrupt 0 { Sleep = TRUE; EZUSB_IRQ_CLEAR(); USBIRQ = bmSUSP; } Along with these 2 files I am including ezusb.lib, USBJMP.obj, STATUP.A51, INIT.A51(provided by cypress). Rahul
The code you have posted #includes files I don't have, calls functions that aren't defined and runs on hardware I don't have. You need to strip the program right down to a main function, ISR and variable declarations. If that still doesn't work, post it. If it does work, add your other code back in bit by bit until the problem reappears. You will then have a pretty good idea where the problem lies.
This code is taken from an example supplied with the Cypress development toolkit. I have only changed the code in Sof() function. The main functions etc .. is the minimal code for initialization and support for a ISO endpoint and bringing up the board. Thanks Rahul
